Climate Control Fan Problem
Hello all;
I currently own a 1994 Jaguar XJ6 Sovereign Series and was advised the XJ40 Forum was the one to seek help?
Essentially my climate control fan wont spin, when the system is turned on the heaters heat up, the indicator lights on the buttons all light up, and when stationary or moving you can feel heat coming through the vents and dash as moving air casually pushes it through and the vehicle itself warms up. Big problem comes from the cold when windshield needs defrosting or vehicle warm up.
Looking for advice on where to begin looking to find the problem?
I've started with only the fuses and all seems to be in good order.
Hello all;
You can check to see if you have power at the fan by backprobing the plug at the fan (I think it's the brown wire) - there should be power (12v) on that wire even with the ignition off. If that wire is dead it is almost certainly a problem with the solder joint in the fusebox. Re-flowing the joints will fix the problem. Had to do both of mine - went almost all winter without fans - not fun.
Using the same logic (that both wouldn't quit at the same time), I replaced the microswitch in the control unit but symptoms persisted. Apparently the microwitch problem is more of an issue with early XJ40 control panels and not so much with the later ones.
From a tip from another 94MY owner on the forum, I re-soldered the driver's side fusebox and my fan came to life, again, only on high, so I decided to re-build the speed control circuit (transistors etc) in the driver's side fan - the passenger side required removal of the airbag so I thought I'd do the easiest one first.
While I was waiting for the parts to arrive, I removed the passenger side fusebox to have a look, and to my surprise the very same solder joint had cracked in that box too. I re-did the solder joint and found that I now had low/med/high airflow, albeit only from the passenger side, the driver's side still only blew on high. About a week later I removed the driver's side blower and rebuilt the transistor speed control and replaced the relays.
That was it. Fixed!
Jag-GM (10-18-2013)
Late model XJ40's (like mine and a number of others!) have a problem with cold/cracked solder joints in the fuseboxes. The main joint to crack is the center joint which powers the blower fans.
![](https://www.jaguarforums.com/forum/attachments/xj40-xj81-25/59517-climate-control-fan-problem-blowerpowerwire.jpg?dateline=1382458233)
Jag-GM (10-22-2013)
How can I locate the switch you are reffering to? (where can I find it) and how hard would it be to install/remove?
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
