Cooling system fail....Again
Its funny so far maintaining my XJ6 has been a fairly straightforward job, but again the cooling system popped, this time the recovery tank. The parts to replace are straightforward enough but damn they are expensive.
The radiator was listing out at $1000 and a cost of $700 but even at that I couldn't find one, I ended up finding a used on for $100 so I lucked out.
The coolant recovery bottle lists for $320 and even used ones are almost $100. I am going to the PNP tomorrow as they have 1 car listed in my year range and hopefully it will have a tank. its $9.99 IF they have it, otherwise the car gets parked until I can source one.
Hopefully this will be the last thing though as everything else has been replaced.
Cinny65 (06-02-2014)
Received 13,006 Likes
Hi Jeh,
Sorry to hear about your cooling system issues - I went through the same problems last year and had to go the salvaged part route also. For others who may view this thread in the future, below are links to photos of the work I did on our '93.
Cheers,
Don
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
So I tried to make the earlier bottle work. It physically fit in the car but as soon as I pressurized the system I found a leak....under the intake manifold
And of course the hose clamp was clocked so I couldn't get at it. . So I spent about 25 minutes getting at it so I didnt have to pull the manifold. I fixed that and tied the system again.
The replacement bottle failed at 10 psi.
I gave up and a few days ago found one on ebay so hers is hoping for next week.
Bottom line - It looks as though an older bottle will work minus the level sensor but a 95-97 wont fit at all.
I'm still having issues. The car boils over as I approach the house. The last 1/3 of a mile is on a dirt road and I'm going slow. The gauge doesn't indicate that the cars hot, even a little, but it boils over past the recovery cap.
I first thought head gasket but the engine doesn't build pressure or smoke like a head. I'm going to get a new cap tomorrow and if there is no change pop the stat and look. Though it's not acting like a stat.
A little stumped as I usually don't see caps go bad unless they physically break but any things possible.
The pressure cap on the header tank/reservoir of our '93 failed several years ago, so that may very well be your problem.
Reading your prior posts, you've replaced the thermostat, so that seems less likely (although you don't say how long ago that was). My sense is that we tend to get about 5 years out of a 'stat, and so far they have always failed in the open position, but now that I've said so the next failure will no doubt be closed...
Please keep us informed!
Cheers,
Don
93SB (05-30-2014)
Hope it's that simple! Fingers crossed!
The speedometer stops working, and at idle it stalls. Ive finally got the thing to pop a code and its leading to a VSS for the speedometer. So it may be easy as well....Maybe. But thats another forum.
trosty
26
12-18-2022 06:40 PM
