Creaking sound from rear on 93 XJ40
Hi Everyone,
My 93 has developed a creaking sound from the rear that doesn't happen until the car has been driven for about 10 miles or so. All four shocks were replaced about a year ago and I don't think it's the exhaust. The breaks are also new. It happens when the nose dives during breaking and when the car levels out again. I can also create the noise by pushing down on the back of the car. The car does not have self leveling as its a regular XJ 40. Any thoughts?
Received 13,089 Likes
Hi Xdevo1973,
Do you notice that the sound is coming more from one side or the other?
Off the top of my head, one likely possibility is that the rear shock bushings are making the noise. But the fact that it doesn't happen until the car has traveled 10 miles or so is curious, as is the fact that it has been a year since the shocks were replaced. Often, if the shock bushings are not greased prior to installation they will produce a "dry squeak." Perhaps your bushings were installed dry and have taken this long to begin to squeak, or not enough grease was applied and it has dried up.
Another possibility is corrosion around the base of a coil spring rubbing in the spring pan.
It's possible a perished suspension bushing is allowing things to rub together somewhere. Maybe one of the bushings in the differential support pendulum or wishbone tie. Perhaps the problem becomes worse when the differential heats up.
You could back up the car on ramps and have someone press down on the body on each side while you listen from underneath to see if you can locate the source. If that is inconclusive, it may take a good inspection with the car on a lift and the suspension hanging free to find the issue.
Cheers,
Don
93SB (08-01-2017)
Cheers,
Don
