Cruise Control Vacuum Pump
Hello all XJ6 owners. The vacuum pump for the cruise control on my 1992 Jaguar XJ6 needs replacing and I am having one heck of a time finding one. The OEM manufacturer is Hella, the part number is 003 572. I'm wondering as I can't seem to find the actual vacuum pump if there are alternatives out there. Any help is greatly appreciated.
Welcome to the forums Rick,
I've moved your question from X350 for the 2003-2009 XJ's to the XJ6 & XJ12 Series I, II & III forum for the 1968-1992 XJ's. Members here with the same model will be able to help.
Received 10,988 Likes
GGG (04-01-2021)
Received 6,361 Likes
Good now? [img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAA f8/9hAAACw0lEQVQ4jXWTWUgUUBSG71NPEfTkixQlGhFkWRr4ohKi BU4GIjMtaqZJiDozLtXouAujYeWoqQ+F5RLuCyqaYjKl4VITKK bYOItZ44zagopl9vXggJX18MO5cP+Pe+75jxBC8LdsC0uMvuyg oVpF9YOb9PU0YrFYd9xzaPtgty3TUxfCQL0Hk/3+zI1KMQxdYKApEG32UVQKP8zmHaCtYs40yViHJyuGENhUALcA FWykwddUvlluMNguRRntytjI6J8Au83O1LNT8DUSyGBtXQ1of1 Mp658yYTUPfV8M8VcOYTLObwP0vRKwS4EMCu8GIYQgIOAY8ASo QyLxQghBQXYQrOTT9khGQpT3FsBmnWdB7ws/Y4E7BAd7IIRg167dQBPQxp7dexFCcObscaCCt7pk1PGezBpMiJ mJZtZN5wA5cJsfG0WUlFxidrYI6AA6sZjLKdZG8H2jArjPxzdq yjQSulqrEMO9SjY/yIAkoACoBFqAVscLWoBOoBtoBMqwT2RRWxbOPU0MYrA7hbXZUC AFgyGJ6ekMoNaheoepAWhlfCKPDzNZLL3Npar0MiWFcYjx160Y h04DSnQvInBz3ecwVQM1jo9sANo54OLM+EAS5leZFGUH0dtVh7 B+XKCnxp1vxgggl/ArJ4mK8nEYmx2tNBIq80YZ4wcrxTytiyMt7hQW8/utMVYWBzDS5cem9TqQg1zhzUkvF+SJgSQoAvE4cZB0hT+s3kPf l4w29zzqxIDtHNhsn9GonBlsD+Tz9DUgky8mJR01MjqrL7I8pY IlDcPdcsoLQokNO8KC9dOfUTa8M6KMduKx1pPhLhnGkRiWphRY JxLR98XS/DCMrBRfIkPdeDdj+PcyLS6ukpMexlWpE6nxhynM9CE/zQ95lDtSyX6yUsNYXFz5/zZug9bQDfRTcT+f8lINg891/zIihOAX5x6anoN7NvsAAAAASUVORK5CYII=[/img]
Doug (03-31-2021)
Don B (04-06-2021)
Received 13,424 Likes
Hi Rick,
Welcome to the Jaguar Forums! It's great to have you with us.
Have you confirmed that the vacuum pump is inoperative? A more common issue is the dump valve sticking or failing in the open position, which will prevent any vacuum in the system even if the pump is running.
A good salvaged part is one option. Check with eBay sellers who are parting out 1990-1992 cars and if they don't have a vacuum pump listed, contact them via eBay's message system to see if they have one.
According to the schematic (below), the vacuum pump contains a valve which is controlled by the Cruise Control ECU. It seems possible that you could use a 2-terminal vacuum pump and add a separate solenoid vacuum valve such as those used in the climate control system of the XJS. Generic ones are available on eBay and elsewhere.
You can download the wiring diagrams at the link below:
Jaguar XJ40 Electrical Guide 1991-1992
Cheers,
Don
Cheers,
Don
motorcarman (04-07-2021)
