Daimler XJ40
RE: Daimler XJ40
It can be used , the trick to use such an item is you must wire the unit cable to radio's existing FM module . You can also use this item w/o having a CD button radio .
PS- Your aftermarket stacker has an external control module right ? It will have to be wired to your car's audio too .(so as to skip,listen to the CD musics )
Guest
Posts: n/a
RE: Daimler XJ40
I always think Jaguar's are meant for Alpine. It took me a long time to find what I wanted without wanting to take the originality away from the stock radio area. A good Alpine head unit will run you 200 bucks and looks perfect, get an Alpine CD changer for the trunk and it gets connected directly to the head unit and you can use the controls on the head unit like a factory cd changer. It's awesome! Plus you dont have to mess around with a different kind of changer where you'll like mentioned before be using an FM station to transmit the music..it sounds terrible like that I used to have a Pioneer set up like that before I switched everything to Alpine. Good luck!
FS[SouthEast]: Books - Various Jaguar Titles
SCMike
11-25-2015 07:55 AM
