door wont open... from inside or out
okay so i have an 88 xj6 my rear driverside door wont open from the inside or out ive tried to firgure out a way to get the pannel off from the inside but i cant seem to find a way im pretty close to taking the pannel off so if anyone has some advice before i go through all that work it would be great
Does it lock/unlock with either the central locking or manually with the locking button? Or is it a door handle issue?
If it's a locking issue (electrical problem with the locking solenoid) have you tried disconnecting the battery, pulling the door locking button up and then opening the door?
Those '88-89 models common with this quirk problem . There is a bolt that needs to be loosen first . It's inside the interior door handle , rectangular plastic clip may cover it . You are also going to remove wood panel .Then, upper door panel needs to be pushed up but be careful and easy . This is what I stayed on my mind others will chime in for sure
RaceDiagnostics
09-13-2015 02:22 AM
