Dreaded bushing noise
Ok I have figured out (thanks to this site and some great posts from Don) how to replace the front shock bushings but I have 2 questions.
1) how likely is it that the shocks themselves need to be replaced (not noticing any weird handling issues or bounce)
2) I have been looking at parts on Jagbits and they have 2 bushing kits. I may answer my own question here since I have emailed them, but, does either kit come with the washers etc? and is one set better than the other (one is 2 x more expensive).
In any event I need to get the bushings replaced as I looked underneath and there is literally just a rubberband sized piece of the bushings left. Of course I have the rattle over bumps too. Thought it was inside the car but thanks to you fellows I looked at the bushings and... well bob's your uncle.
Just for reference 1992 Vanden Plas vin SAJKY174XNC651272
On a side note is there a way to tell if the SLS has been removed from the car? I can't tell but rear seems fine.
Not sure of the actual part numbers but when I got shocks for my 94 I think there were 2 choices -regular and a sport version for the stiffer suspension.I replaced mine at 70,000 because the bushings were gone and one rear shock had stiffened up.Replacing them made a big difference in ride and steering feel.You don't mention how many miles are on the car but if the shocks are the originals I think you will see a big difference in replacing them.If the SLS system-do you mean the hydraulic system- has been removed the lines going to the shock would be disconected.The original shock would have been replaced with a non hydraulic type.If you remove a rear wheel you should be able to see the shock assembly and whether the lines are connected or not.And the shocks I got-Bilsteins-came with new bushings and washers as part of the kit.
Received 13,290 Likes
Hi Rutty,
You can test your shocks by pressing down forcefully on a corner and letting go, and watching to see how many times the car bounces. If it bounces 1-1/2 times or less, your shocks may still be functioning well enough. If you count much more than 1-1/2 bounces, then it's probably time for new shocks.
I was not happy with the Bilsteins I put on our '88. They were too firm and harsh. They may have been "Sport" tuned. On our '93 I used OE Boges instead, and they are great. The Sachs I put on the rear were found at a bargain price on eBay, and they're excellent too. Boge and Sachs are now both owned by ZF, the German conglomerate that made the transmissions and steering racks in many of our XJ40s.
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
93SB (01-10-2021)
Chuck Schexnayder
33
10-24-2015 10:20 PM
