XJ40 ( XJ81 ) 1986 - 1994
Driver’s Window won’t roll & Right mirror fault
Old 07-02-2018 | 10:19 AM
Kang Yu's Avatar
Default Driver’s Window won’t roll & Right mirror fault
Hello guys, this is 1993 XJ40(XJ6) owner from Taiwan.
My XJ40 driver’s window wont roll,
and sometimes when I open door to 45 angle it can roll, but it will fault again later.
I open my door card and reorganize window switch box but still doesn’t work, and my Right side mirror suddenly doesn’t work too, anyone can help me!
Old 07-02-2018 | 04:59 PM
jerry_hoback's Avatar
If your window will work when the door is open, it seems like you should look at the area of wiring that flexes when the door opens. You may have a broken wire (or two with the mirror) at the body -to- door area. Good luck.
Don B (07-05-2018)
Old 07-03-2018 | 02:34 AM
Kang Yu's Avatar
the right side mirror can left and right moving,
but can’t up and down moving
Old 07-03-2018 | 07:01 AM
Check for corrosion or a loose plug at the switches and at the plugs to the motors too. The mirror has separate wires for up- down and left- right. When removing the trim panels the wood slides forward off of clips and there is a screw hidden behind the air tube at the top front, besides all of the normal places....
Don B (07-05-2018)
nd4spdlsc
11-26-2019 08:43 PM
Jaguar Forums Editor
Jaguar Press release
07-31-2017 04:18 AM
07-25-2017 09:38 AM
Jaggyx
06-06-2010 10:41 PM
BurgXK8
03-03-2010 11:25 PM
Quick Reply: Driver’s Window won’t roll & Right mirror fault
