driver floor leak, found the hole. where's it go?
I've been hunting for this for a year now. Drivers floor floods every time it rains. Soaks the transmission tunnel foam sound deadener near the floor under the center console, then the floor. A/C drain tube is good. Found a factory hole today with water witness marks, just above the the dash bracket bolt. Definitely the guilty party. Where does the hole go, and how does the water get behind it?
brake, gas, dash bracket for perspective:
wet hole above dash bracket bolt (a/c vent tube visible):
there's obviously another layer of sheet metal behind the hole, so yet another body seam filling up with water from unknown ingress. No factory attempt to rubber plug the hole, unless the new for 93 body with "X percent" fewer body panels was still a mystery to assembly line welders. Anybody here know if the dash bolt pokes through the floor into the transmission tunnel or dead ends inside the floorpan?
Reverend Sam
05-23-2019 03:42 PM
