Electricity leak.... how to find it , do i have a problem in my logic ?
The latest post i have done was about a fuel problem, and the help i had from this forum was incredible, and was essential in order me to fix the problem.
my car: Jaguar XJ6 1993, 4L, and here is the problem:
i have a battery/electricity leak. The car runs fine, but as soon as I turn it off, within a couple of hours my battery is drained. For that reason, now a days in order to use it, everytime I park my car, i have to disconnect the battery.
here is what i have done:
1-I have replaced the battery for a new one ( totally charged) so battery is not the problem.
2-I have connected a Buzzer -in line- to "hear" the battery leak in order to narrow down the problem (see picture attached). After that I have removed all fuses (ALL fuses) from the 3 fuse boxes i know my car has: passenger side, driver side, center (below the central arm rest), even though the Buzz sound is still there, meaning the leaking is still there.
.........no progress so far, any idea how to follow ?
what circuit in the car is NOT having a fuse in it ?
where could the energy drain could be ?
you were ABSOLUTELY RIGHT !!!!!! , as soon as i disconnected the Alternator, the "Buzz" went off as long as the electricity leak....
so.. now i know i have to change the alternator.
for removing/changing the alternator should i access it from the top or from below to the car... ???
seems pretty complicated to take the alternator out of there, any advice ?
thanks in advance !!!!
hafren
08-30-2023 03:42 PM
