Essential spares- what won't you leave home without?
So this should be a fun and informative thread. If you ask about common engine failures, the list could be a mile long- so more objectively, what spares do you carry around with you? My partner owns an old 420 merc and will always have a spare fuel pump relay in the glove box. This makes me wonder what would be a good idea for my same era jag. So, what are your essentials?
Received 13,087 Likes
Great question, BeckBeck!
In addition to the typical small set of tools, jumper cables, spare quarts of oil and roll of duct tape, I put together this kit for our '93 (sorry the large photos are not currently working):
XJ40 Roadside Breakdown Kit
Obviously some of those parts, like the brake accumulator and pressure switch, are not necessarily "essential," but if I ever needed them on a road trip it might take days to source a replacement. A spare known-working CPS and known-working relays are must-haves, as are some spare bulbs, especially for the low/dip beam headlamps and brake lamps.
Cheers,
Don
Cheers,
Don
BeckBeck (05-24-2017)
Some of the original relays have built-in suppression resistors or diodes, so for a long-term replacement you have to consult the Electrical Guide. If you can't find the correct type, you can solder a resistor or diode across the relevant spade terminals and position it alongside the base so the relay will seat properly in its socket.
Here's a photo of a 5-terminal relay I just grabbed off the web:
Some relays, like the one above, come with a mounting tab molded into the body. If that tab interferes with proper placement in the car, you can just cut the tab off.
Cheers,
Don
