Exploded diagrams.
Hi John, check out the FAQ at the top, you can download the XJ40 book, which is a decent read, also you will find a link to a place for downloading the electrical diags for your car, and if you go over to the General Tech Section you will find a link to Christo's JTIS download site.
What bits were you specifically looking to remove and replace because you will find that a lot of the guys have posted repairs etc with pics to go with them?
Hi Guys,
Removed the sunroof today.
Just a little diferently than the JDC instructions.
First I opened the sunroof as per instructions and then removed the 4 screws on the front flange of the outside part of the sunroof.
Then the instructions said " pull forwards and lift out "
NO GO. Something holding it in still.
Finally got the wife to close the sunroof as I held onto the outer part and lo and behold, it lifted out ok.
Next step is to remove a metal hold down peice from the front of the lower section of the sunroof and then just lift out the lower section.
DO NOT remove any of the arms as advised in the instructions.
I have now taken the headliner and sunroof to my local motor trimmer who has quoted Aus$140 to re cover them.
It has been a good three or four days of a steep learing curve but I am enjoying it so far.
Thanks for the help and will keep in touch, will try and put some photos up too.
Regards,
John.
Regards,
John.
Hi Guys,
Progress pics on fixing up the headliner.
Sorry they are just following removal, as most of the work was done before I joined this forum.
![](https://www.jaguarforums.com/forum/members/john-jag-52168-albums-johns-1989-jaguar-sovereign-1539-picture-jag-1-4131.jpg)
![](https://www.jaguarforums.com/forum/members/john-jag-52168-albums-johns-1989-jaguar-sovereign-1539-picture-jag-12-4142.jpg)
![](https://www.jaguarforums.com/forum/members/john-jag-52168-albums-johns-1989-jaguar-sovereign-1539-picture-jag-8-4138.jpg)
![](https://www.jaguarforums.com/forum/members/john-jag-52168-albums-johns-1989-jaguar-sovereign-1539-picture-jag-9-4139.jpg)
![](https://www.jaguarforums.com/forum/members/john-jag-52168-albums-johns-1989-jaguar-sovereign-1539-picture-jag-10-4140.jpg)
All I have to do now is wait for the motor trimmer to recover the headliner and sunroof panel and put it all back together.
Will post pics of final result when complete.
Regards,
John.
Regards,
John.
