Fan blade xj40 3.6
Fan blade xj40 3.6
Hello to all members
I just saw that the engine fan is cracked
I bought a new reference fan EAC 9367 A
but trying to mount it rubs against the water pump
the fan that is on my jaguar more resembles the picture below
yet it carries the same reference ???
could you give me your opinion
thank you
thank you
Hi - you need to check part numbers here:
Find Jaguar Classic Parts Online | Jaguar Classic Parts UK
use your VIN number and model to locate the correct part number and see if it is the same as the part number on the fan you bought - if not, return the part and buy the correct one.
Larry
Larry
The following 2 users liked this post by Lawrence:
93SB (05-25-2016),
frenchfairplaydriver (05-03-2016)
Received 12,932 Likes
Bonjour Sylvain,
I happened to be checking some other items at jaguarclassicparts.com and looked up your fan. It appears the original part number was EAC3263 but that number has been superseded to EAC9367. The "A" after the part number of the fan you received probably stands for "Aftermarket," but the fan you received does look like the illustration at Jaguar Classic Parts.
However, I searched this part number at SNG Barratt, who have a French distribution center, and they show what appears to be the correct fan:
SNG Barratt - The Ultimate Jaguar Parts Specialist
Here's the photo:
Cheers,
Don
Here's the photo:
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (05-25-2016),
frenchfairplaydriver (05-04-2016)
Jaguar Forums Editor
Jaguar Press release
04-07-2016 08:58 AM
