Fault Code 89
It is a valve that purges the charcoal canister. On modern engines, fuel vapour in the fuel tank is not allowed to vent to atmosphere, but is collected in the charcoal filter and then periodically purged into the inlet manifold via the Fuel Purge Valve. My Rover 75 (previous car) had one of these and when it started up it sounded a bit like tappet rattle and always got people in a panic that their engine was knackered
Thank you for the comments. I found a troubleshooting procedure online for determining the fault in the fuel purge valve and will check it out. Can someone tell me, is this located behind the liner in the fender? Also, the procedures say there is a vacuum line connected to the intake manifold. Can anyone tell me about where it connects?
Okay. So I found a troubleshooting procedure online, but it doesn't say how to access the fuel purge valve. I'm pretty sure it is under the left front fender, but it appears to be enclosed by fender liners. To get to it, I think I need to remove those fender liners. Am I correct in my assumption?
Yes, you are correct. Get the car up on a stand and remove the LF wheel (index the wheel/stud so you put it back on the same way it came off.) Remove the plastic liner from the fender. There are 3 bolts with 10mm heads bolting the canister up to the underside of the well. Remove these and allow the canister to drop and you will be staring right at the purge valve. The other end of the purge valve vacuum hose goes to the under-side of the air plenum of the intake manifold. (just behind the throttle body). Good hunting!
Well, bummer! I found the charcoal cannister and in the fender and the first thing I saw was a broken vacuum hose. Thinking that I had found the problem, I replaced the hose and hooked everything back up. But the fault code won't cancel, so I guess the problem still exists. Back to troubleshooting.
Thank you Robert. I had a 89 code for months and could never get around to it. And I followed this thread. Tonight I got at it. Same exact thing as yours. The rubber connector was deteriorated, cracked and broken. I had to get real creative to replace that piece. I did, fault code gone.
philwarner
25
06-26-2021 05:43 AM
