Fuel Fail 22 Code
Fuel Fail 22 Code
Hi guys,
As im dealing with a LHM light, i have decided to make a separate thread on this issue....
So I'm getting a fuel fail 22 code on the vcm, i know it has to do the with the fuel pump circuit.. so i checked and cleaned the round fuel pump connector under the rear seat with electronic cleaner, i cleaned and tested the relay then just replaced it, i also cleaned the terminals on the fuel pump and im still getting the code, ive reset the ecu as well. could it be a faulty fuel pump? the humming is very loud if that means anything, keep in mind that the pump is mounted on the cross member under the diff on the left, not inside the tank.
what else would cause this ff22 code on a 1990 jaguar VP 4.0?
Received 13,093 Likes
Hi Marco,
Download the AJ6 Engine Management System Diagnostic Manual at the link below, courtesy of our forum member Gus:
http://www.jagrepair.com/images/Auto...stem%20S91.pdf
Read pdf page 90, then follow the diagnostic flow chart on pdf page 91 and let us know what you find.
Cheers,
Don
Cheers,
Don
Welcome to the Jaguar Forums! It's great to have you with us.
The link works for me, but if you still can't get it to work, visit jagrepair.com. The manual is incorrectly filed under the Jaguar XJ6 & XJ12 section instead of the XJ40 section where it should be.
Also, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Grandcouper
06-04-2023 03:56 PM
62sunbeam
10-06-2013 10:08 PM
