Fuel fail 22 Help!!!
Have you checked to see if your fuel pump is getting power? The Fuel 22 can mean the fuel pump isnt getting power. The connector is known to suffer from arcing and melt. I had the same issue and I removed the fuel pump connector at the evaporator flange and directly wired the pump. So far, no issues whatsoever with the fuel pump operation.
