XJ40 ( XJ81 ) 1986 - 1994
fuel failure 44
Old 08-23-2012, 03:38 PM
Phil63's Avatar
Default fuel failure 44
Hi, I'm a new member I bought a 1991 xj40 3.2, 3 weeks ago and it is displaying this message has rough idle, loses power, and cuts out. it also loses fuel pressure. does anyone know what could be causing this.
Thanks Phil63
Old 08-23-2012, 05:39 PM
Rob Evenson's Avatar
Hi,
Fault 44 is your Oxygen Sensor, probably needs to be replaced. I have an 89, so someone else may have an additional suggestion for correcting without replacing the sensor. Not too expensive to replace, I've had to do it once about 8 years ago. Check out the info on both of these links, the first is a little more comprehensive for trouble shooting.
http://www.jag-lovers.org/ebooks/vie...Vsection=12.44
AJ6 FAULT CODES AND IDLE SETTING / AJ6 Engineering
Good Luck
Rob Evenson
89 XJ40 123K
Mobile, AL, USA
Thanks Phil63
vsol
08-29-2018 09:46 PM
Pilotman11
11-19-2015 12:55 AM
hoodun
10-02-2015 10:13 PM
mrobinson
09-18-2015 07:20 AM
Tim Goz
09-17-2015 09:11 AM
Quick Reply: fuel failure 44
