Fuel Fault 39 1991 XJ40
Hi everyone.
Restoration is proceeding nicely. The car threw a fuel Fault code 39 today Now I know it has to do with the EGR system. What I need is where can I find a proceedure to follow to determine what needs to be replaced? Anyone in the forum? Your help is most appreciated.
It is an EGR temp sensor circuit fault. The temp sensor is under the intake manifold and watches for a rise in temp when the EGR valve actuation is requested by the ECM. If no rise is seen then a fault is logged. Most likely cause is a carbon buildup in the EGR tube connection at the intake manifold.
Jaguar publication S91 has all the explanation and fault finding engine managment info for the XJ40 1990 to 1994 MYs. It is in paper or .pdf format but it is over 13mb so it will not email with most email providers.
bob gauff
bob gauff
Thank You
joesoap
09-10-2015 01:09 AM
OkieTim
09-08-2015 04:48 PM
