Fuel pump relay. HELP.
The Main Fuel Pump Relay should be in the trunk or on the passenger side firewall, just inboard of the Main electric Relay. there is a relay switch in the Inertia Switch also. Check for voltage to the fuel pump on the harness connector near the fuel tank. Its under the carpet in the trunk. Work forward from there.
