Gearbox Fault Light XJ40 1993
Hi there !!
i found this forum the best knowledge around internet, here all my questions has been answered, so here i go again !!!!
Car: 1993 xj6 4.0L
since a couple of days im having the TRANSMISSION LIGHT PROBLEM on the dashboard.
there are NO fault codes under de VCM, and car runs perfectly, check fluid in the transmission. Also change to (Sport) and to (1) and to (Normal) mode and nothing happens,light is still there.
Also i have disconnected the battery to reset lights (maybe is just VCM fault codes who get reseted by disconnecting the battery...), but Transmission problem light is still there, so far no problems but the light, any clue ?
should i buy the OBD reader to go deeper or there is some other test that i can make to see why the faulty light is on?
Car: 1993 xj6 4.0L
Hi there.
just tested and disconected:
left fuse box: C2, C3
center fuse box #10
not luck still.
one thing i noticed is that when i switched from (Sport) to (N) to (1) , there is no light on the dash telling me what type of gearbox i am. (if i do not remember wrong before it was )
any advise is wellcome
center fuse box #10
not luck still.
Hello, does the diode on the sport button light up when you press it, this might help give you an indication as to whether it is switching into Sport or not.
If you can get under the car, you might be able to check the electrical cable connection to the trans.
But it would help if one of the techs could dive in, because that's about it for me and electronic auto transmissions.
hi there.
i notices this:
1- the Letters on the gear box base, are iluminated ( Park / Neutral / Reverse ) but the ones that says (D / D /1 / 2 )
2- the switch below the gear shift ( that change Sport / N / 1) has no light
3-in the dashboard i see no iluminated the mode "Sport" Nor the Mode "1". when i change it from the switch below the gear shift. ( and of course the light in the dashboard like there is a problem in the automatic transmission, as mentioned in point 2.
Translator : i went below the car and i could not find any electrical cable connection to the trans.
any advice from here ?
i notices this:
Problem solved !!!!
it was the Transmission Relay., the one with Purple Base on the relay bank by passenger seat accessible from opening the hod.
i got to this solution by following this troubleshooting guide:
http://www.jag-lovers.org/ebooks/vie...j40&Vsection=8
thank you Translator for the help !
OkieTim
09-08-2015 05:48 PM
