XJ40 ( XJ81 ) 1986 - 1994
GM 4L80E Issue
Old 07-05-2024, 11:56 AM
V12Lover's Avatar
@Don B : Thanks for your tool recommendations, I am trying to find something similar in Germany. I think
these test leads these test leads
might do, though I am surprised how expensive just a few cables can be. https://www.conrad.de/de/p/vigor-v4326n-messleitungs-set-1-set-2866075.html?hk=SEM&WT.mc_id=google_pla&gad_source=1&gclid=Cj0KCQjws560BhCuARIsAHMqE0GkbE-HsgZigj3sCWVkZDENSQEkYS5nvKTTTRRvfvjDGErRMHPoTqYaAitxEALw_wcB are even more expensive but also more extensive. And https://werkzeugstore24.de/bgs-krokodilklemmen-kabelbox-selbstaufrollend-15-m-9401.html?gad_source=1&gclid=Cj0KCQjws560BhCuARIsAHMqE0H9W96cXp-6tpf8brp103Tvz2J1VhcYBJemhzGdYknEma1ZdFA7gYQaApOhEALw_wcB.
@newyankee
I watched some videos of 4L80E (valve body) overhauls und reinstallations, the TCC solenoid should come out without removing the valve body (jal1234 also confirmed it), but the valve itself probably not, there is too little space and it seems like it needs unlocking from inside. Actually I am not 100% sure whether the TCC is working or not, but I guess the rev leaps in certain situations definitely point towards it.
@Gijzzy I tried, but I didn't manage to flash out any code, not sure if that means something is wrong with my TCU or whether I just lacked the right tools .. I hope the latter is the case.
  #62
Old 07-06-2024, 03:49 PM
V12Lover's Avatar
Just to cry wolf: what if the tranny had to come out completely (e.g. for converter replacement), how could that be accomplished? I doubt the upper mounting bolts can be reached from the engine compartment from top, would the whole front axle + engine+ tranny have to come out? Or would it be sufficient to lower the rear engine mount to access all the mounting bolts? The official workshop manual has a gearbox chapter that roughly describes how the transmission is designed and integrated to the car, but there is no mention on neither how it should be serviced nor how it could be repaired or replaced.
  #63
Old 07-06-2024, 05:55 PM
jal1234's Avatar
Using an engine bay cross bar to support the rear of the engine, unbolt the trans mount and lower back of trans. Use very long extensions to remove bolts while supporting the trans with a trans jack. You probably will need to remove engine driven fan so that it doesn't hit the fan shroud when the back of the engine is lowered. Of course you'll likely need to remove exhaust portions to gain clearance and remove the torque convertor to flex plate bolts, etc.
Jon
  #64
Old 07-11-2024, 03:12 PM
V12Lover's Avatar
That doesn't sound too bad. But first let's see what I can about it leaving the gearbox in place. Before it reaches temperature everything seems to work well, so according to what I have read it could fairly be something related to either wiring harness, oil pressure or a hampered TCC solenoid or valve regulator. A new internal wiring harness + TCC solenoid wouldn't cost too much and would be fairly feasible (not considering the exhaust), but when I disconnect the old harness it could very likely happen that the connectors on all solenoids break due to brittleness. So indeed it would probably be a good idea to have a complete set of solenoids at hand once you look behind that door.
I had another look at the oil pan situation and I am not quite convinced one exhaust pipe has to come out in order to take the pan off. There is a little space towards both sides, if you manage to loosen all the bolts, one could possibly fiddle the pan out between the exhaust pipes.
  #65
Old 07-14-2024, 03:08 PM
V12Lover's Avatar
I did probe a little more today, I am able to get to all the oil pan bolts and once it is loose, I should be able to drop it a few cm and slide it to the front towards the engine oil pan. Then I think I should be able to twist and tilt it and finally slide it out. If necessary I could remove the fly wheel cover, it's just a few bolts. And if that doesn't help it, I could even undo the engine oil pan, that should finally give enough clearance. I think I'd rather do a engine oil change and pan gasket than ruining the exhaust. The only issue I see: someone fastened the pan bolts to excess, I tried to undo one with a cranked wrench, but it didn't move. That might become a littly tricky, because there are some bolts than I cannot reach with my power wrench.
I also did some more test driving, I think the TCC works, even when the gearbox is at temperature and the TWL has come on once (just needs a restart). But I only notice it when coasting down, so when it is disengaging. Don't notice it engaging, but it has to otherwise it could not disengage. The TC shudder I sometimes notice could be also related to topography, coasting down downhill seems to facilitate it.
  #66
Old 07-15-2024, 04:42 PM
V12Lover's Avatar
Man that sucks, the bolts sit so tight, can't get them loose with a hand wrench. Even my 80NM powerwrench couldn't break them loose, needed a huge ratched with telescope prolongation and surely 100-120NM to loosen one of the easily accessible ones. So it looks like I do have to cutoff the exhausts to get all of them. What would you recommend, cut them at the weldseams or somewhere inbetween?
BTW: Observed the TCC disengage today while coasting down and TWL being on! That actually contradicts what the GM manual says, with error code 68 it should inhibit TCC operation ... as well as manual shifting. So maybe I have another error code? Or maybe even multiple, interchanging error codes? In that case a proper diagnosis would be great, but once again I am turning cycles.
BTW2: It looks like the connector of the inner wiring harnes is held to the gearbox housing by a hexagonal ring. That 's barely accessible with the rear transmission mount being in place. I watched some videos of 4L80E overhauls, they always just tapped the connector with a hammer and pulled it through, but these transmissions were all removed from the car.
Where to cut
Connector
  #67
Old 07-15-2024, 09:53 PM
jal1234's Avatar
The videos you watched where they removed the connector by tapping it out had the standard GM wiring harness, not the Jaguar/Rolls Royce connector. Completely different.
Jon
  #68
Old 07-16-2024, 04:25 PM
V12Lover's Avatar
I though something like that. How did you manage to change it?
BTW: Do you see that insulation mat? It's hanging all over the transmission, I doubt that that is the way it is intended to be. Shouldn't it be attached to the propeller shaft tunnel or does it belong there at all?
  #69
Old 07-16-2024, 05:45 PM
jal1234's Avatar
I didn't change the harness, as it took too long to come. I'll likely change it the next time I do fluid and filter.
As far as the mat goes, I'm not sure. The TH400 cars had a foam sound deadener wedged beteen the trans and tunnel. It wasn't glued in place. I don't recall what was there on my 95 V12.
Jon
  #70
Old 07-16-2024, 06:06 PM
jal1234's Avatar
I just looked at my new harness. The connector is held in by a large nut on the outside. You'll need a 32mm socket to remove it.
Jon
  #71
Old 07-17-2024, 04:52 PM
V12Lover's Avatar
Jon
That's interesting ... then it seems to be the same on the XJ81, that foam mat looks like it is just wedged inbetween the trans and tunnel.
Jon
That's gonna be tricky, with the exhaust pipe (and the foam mats) in the way, it will be difficult to reach the connector nut by either a socket or wrench ... maybe with a prolongation from behind the trans mount.
Before cutting the exhaust I wanna give it another try, ordered me some special 10mm cranked wrench that would allow me to put a straight prolongation on the opposite end. Maybe I can get the pan bolts off this way.
  #72
Old 07-19-2024, 07:20 PM
V12Lover's Avatar
I did some more test-driving and I am starting to doubt it has anything to do with the TC or TCC, because as long as I avoid accelerating in 4th gear at a certain throttle angle, there will be no fault and it looks like the TCC is operating as designed, even when the gearbox is at temperature. It still could be anything like a bad wiring harness, or solenoid or whatever, but now I am rather thinking about a speed sensor. The engine speed signal seems to come from the ECM (respectively the crankshaft position sensor), does anyone know where I could probe that? Would the engine fire up at all with a bad crankshaft position sensor?
Another reason why I cannot nail the cause down might be that the documentation I have does not fit the model year of my XJ81, it's from 1995 so that is actually X305/ late XJS era. Maybe that would also explain why I cannot flash out hte error code, I might be referring to the wrong pins.
Besides that I am starting to notice a slight pulsation in the driveline when going at a steady speed since I have added some more ATF. It feels like the overrun clutch is slighty engaging and than disengaging again. Don't know if that means anything.
  #73
Old 07-19-2024, 09:23 PM
jal1234's Avatar
The output from the engine ignition module could be probed either there or at the TCU. The transmission also has its own speed sensors, one on the input, and one on the output. Yes, the engine needs the speed sensor to operate to run.
paulzahra
20
10-04-2023 03:59 AM
Bayside Graphics
04-08-2022 09:11 AM
jean HJ
03-27-2022 10:59 AM
Dazzler
12-17-2014 08:00 AM
chrisp1981
02-01-2013 05:49 AM
Quick Reply: GM 4L80E Issue
