Green Mineral Oil leak
Hi there,
I have a 1992 Jaguar 4.0 liter engine and it is leaking the green mineral oil.
i notice that it leaks on the top cover that screw on the container.
When i drove a few miles everyday i notice a green oil spilling on top side of the cover itself.
is there something i can do on these to tighten it or i really need to change the container itself?.
your help is highly appreciated.
thanks in advance.
thanks in advance.
kcidmad,
You might try posting a want ad in the forum sections (main page at the bottom) and see if someone has a damaged container with a good cap.
Is you cap cracked? Sounds odd that it is seeping out the top. For a temporary measure, you may want to go to an auto parts house and get a product like JB Weld for plastic repair or water weld until you find a good cap.
http://www.jbweld.com/products/surfa...ns/automotive/
Thanks Rob for the reply.
I am going out this weekend to the junkyard to see if they have a good container that i can use.
now to my next question. If i need to replace this container, what are the steps necessary to do that?
Is it just a straightforward thing of just emptying the container, then unscrew them including the two host that goes down and then refit back.
Do i need to do something else special?
please advise?
again thank you in advance.
kcidmad
please advise?
kcidmad
Are you referring to your power steering reservoir? You know, when leaking power steering fluid it looks greenish, are you sure it is mineral oil and not power steering fluid?
Get a turkey baster and suck all the fluid out of the reservoir before removing the hoses. Be careful when removing them, they are on very tight because there are nipples on the extensions coming off the plastic reservoir, don't break them.
Yup, a $.50 clamp has cost me quite a bit in mineral oil that leaked out.
aholbro1
08-05-2021 05:02 AM
OkieTim
09-08-2015 04:48 PM
