Head gasket AJ6 4.0 engine, 1992
I am working on an AJ6 engine, with what I assumed was a blown head gasket. I have the head off, but found some weird things. I think the head has been off before, but there is no history on the engine.
I assumed that with cilinder 1 on top dead center, both cams would have the notch exactly straight up. But when I set the intake cam with the notch straight upt, the exhaust cam is a bit off.... I hope it shows on the picture:
Also, with number 1 at top dead center, I would expect the rotor on the distrubutor to point at terminal 1 on the cap, but it's already past the notch on the distrubutor housing, which aligns with the terminal going to cilinder 1.
I am uncertain if something is wrong, but it doesn't feel right to me. What do you thinkg?
Hi, thanks for your reply.
I agree that the timing should be late, as it fires before TDC. so rotor might be at right spot.
The chain is in good condition and tight. No signs of stretch. Also the tensioner was fine.
The exhaust cam is off (when I set the inlet cam correct with the locking tool), but it's not a full tooth off on the chain sprocket. I think the difference comes from the finer teeth inside the chain sprocket.
Question now is: how to I teel which cam is off? how do I set it all correct? Is there a notch on the crankshaft pulley to indicate tdc?
The engine ran fine, but maybe a bit more rough than an aj6 should. I have 2 vehicles with AJ6 engines, and the other one runs better. Always has.
and of course there was the constant coolant loss, which led me to the point to take the head off.
Lawrence (04-09-2024)
Thanks, that is interesting. However, I don't think the cams were swapped on my engine.
anyway, it runs again. I figured uit TDC, and it turned out that both the inlet and exhaust cam were off quite a bit. Also the distributor was off. Now the distrubutor does not influence timing of ignition, but it has to be set correct in order to transfer a strong spark. I used my other, well running AJ6 engine as reference and set the distributor as well.
so now everything is back at the correct settings. runs good, but no testdrive yet. maybe later this week.
the 'noise' is a cracked exhaust manifold. The noise goed away when engine heats up. has always been like this. should go shopping for a good set of exhaust manifolds, but they are rare. also, the bit of smoke is oil/grease from wrenching on the thing. cleared up after a while.
motorcarman (04-15-2024)
