Headlamps
I haven't done this conversion so this is all theory ...but ...keep in mind that the so called "brick" headlights are quite different beasts in North America than in all other markets. I can see the desire to replace the rather unattractive non-NA types with quads, but but ...
Anyway, AFAIK, Robman's version of these headlights are single reflector, SINGLE BULB, not quite as wide as yours (these units use a spacer between the grille and the headlight) and manufactured by Valeo.
Your headlights are twin reflector, TWIN BULB, much wider (butt up to the grille) and manufactured by Hella.
To my way of thinking, the modules you have would already be set up for two bulbs - so - if there is a different hookup, all you would have to replace is the bulb connector if the connectors are different from what you have.
I doubt they are, but as I said, this is all theory, never done it. (and in my case would never even consider it as IMNSHO the NA "bricks" are the best looking lights ever produced for the XJ40 )
Some additional setup info for quads can be found in this thread ..
https://www.jaguarforums.com/forum/x...-re-re-172691/
Larry
Larry
tallblondeguy
45
09-23-2009 02:44 AM
