Headliner Trim Clips from eBay
Greetings!
I am replacing the headliner fabric on my 94 XJ and need the trim clips as most if not all shattered as I removed the trim. My understanding is that the original style are NLA. Has anyone used these clips from eBay with success?
https://www.ebay.com/itm/32520072259...mis&media=COPY
If someone has found a better option, I would certainly be open to it.
Thanks in advance.
TC
Thanks in advance.
TC
Greetings!
Thanks in advance.
TC
Thanks in advance.
TC
OK, so the new clips arrived today and I am ready to put things back together after replacing the headliner.
However, I have run into a little confusion. There is a black tube with a screw-in connector that is coming from the passenger rear quarter that was clearly under the headliner, but I cannot seem to locate what it is to connect to, if anything. My car is a '94 base model, and wonder if this was for the interior alarm sensor that is part of the higher line trim, but not on my car. Based on the amount of time that has passed since I took out the headliner, I cannot recall if it was hooked up to anything. There are no rear passenger courtesy lights on the rear pillars, either.
Can anyone help?
Thanks in advance.
TC
Can anyone help?
Thanks in advance.
TC
