Hellooo-locked out of 91 XJ6 Vanden Plas!
Same problem with my car the pass. side never works (even manually) then my drivers side gave out. Had to call AAA and have them come open her up. I can hear the actuator in the door functioning but it does not actually lock/unlock. After watching the AAA guy break in I found it ias very easy with these cars. He shimmed the top of the door open a little bit; enough for him to get a loop of plastic through. Then hooked that loop around the door lock and pulled it up and walla.
A little story:
I never lock my car now, and since where I live people just break your windows if they want in I leave it open. My roommate had his window broken in and they took a study guide and a red bull. Every now and then my meter change stash will come up missing but id rather have it gone minus the broken window.
If I am going to leave it around I do sneaky antitheft things like unplug the distributor, or unhook a few suction lines, I even stuffed a plastic bag in the intake so it couldn't start that way. Another great one that I just found out is to pop up the inertia switch.
A little story:
luvmyjag:
Bummer! If the black key can't get you in (which, if I remember right, should at least get you into the trunk because it can be turned manually, not electronically) I'd follow gunner's advice and get somebody to help you break in and then keep the doors unlocked. Read up on the door locks for this car - which is a notorious weak spot in design. They just wear out. Then you can decide if you want to take the time and spend the money to replace the mechanisms in each door. It's going to be a bit of work, but if the car is in otherwise good shape, it's something you will want to do.
By the way, are you in Madison, Wisconsin?
Cheers,
Scott
Cheers,
Scott
rusty37
04-05-2020 07:40 PM
FS[SouthWest]: Parting out 1999 Vanden Plas
Brewmonkey
21
05-30-2016 12:50 AM
WTB[NorthEast]: 2004 Vanden Plas Headlight Assembly LH
European_Auto11558
09-25-2015 08:05 PM
WTB[NorthEast]: 1996 Vanden Plas Rims
kevinl
09-18-2015 11:00 AM
