help with radio 94 xj6
i installed a kenwood headunit in my xj6. it worked for a little but then battery dies while doing installation. when we jumped it the head unit woul dnot turn on. i used a fuse checker to see what was wrong and it shows the ignition wire is okay but the batter wire is not working. where can i find the fuse for the radio. i dont have the owners manual for that car.
also i cheacked the fuses on the driver and passengers floorboard and the center consle. they were all good.
any other suggestions?
bjjb
i found the problem. the head unit sucked too much power when i turned the ignition. the ignition relay fuse blew. i replaced the fuse 5 times. i had to upgrade it form a 3amp to a 10 amp fuse. thats only because my door speakers are running off the headunit. once i get them on a separate amp it will be fine
