High Idle
I guess the short answer is yes, the IATS could affect idle. At least on the 4.0L cars the IATS is a secondary input for correcting ignition timing but it is not directly involved in fueling. It's possible that if your IATS were stuck at a high resistance or was shorted the ECM could think the ambient temperature is extremely cold and as a result might apply an inappropriate timing strategy.
I don't know how different the engine management system is for the 3.6L cars, but you might find some clues in the 4.0L EMS Diagnostic Manual, which you can download here:
AJ6 4.0L Engine Management System Diagnostic Manual / OBDI
Also, another friendly reminder to please add the year, model and engine information of your car to your signature line. I had to go back to post #14 to be reminded. Some folks won't bother.
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (06-18-2017),
Joel Moross (05-31-2017)
Today I did make some positive progress.
I disconnected the IAT sensor and in place connected a resistor.
Started the car and she sputtered and the idle droped off and came back to 800rpm.
So now the idle is approximately whete it should be. A bit of a shake but an improvement for sure
IAT is on order.
The engine.managment manual, is there such a thing for the 3.6l??
IAT is on order.
Don B (06-01-2017)
If there is, I don't recall finding it as a free pdf download anywhere online, but it may be on one of the DVDs available from the Jaguar Daimler Heritage Trust (jaguarheritage.com). I'm away from home so I can't check the DVDs.
But the principles of operation of the Engine Management System should be virtually identical between the 3.6L and 4.0L cars so the manual I linked to earlier should be relevant to your engine.
Cheers,
Don
Cheers,
Don
93SB (06-18-2017)
Big improvment today!
turns out a huge part of the problem was my brand new Taylor Spryo 8mm ignition wires.
could not hear them arching and had no reson to think they had a proble but, in the dark that was a whole diffrent story. There was spark crawling all over the from the wiress Not ionization. Thought maybe a bad ground so i used my jumper cable from the block to the battery negitive terminal with no change
changed the wires out the univeraal MSD.
My fuel fail 4 is gone.
Idle no longer hunts around on cold start.
Tonight i am going to try and get the idle set correctly.
Cheers!
Don B (06-09-2017)
KenAdamson
37
05-26-2020 05:40 AM
FS[NorthEast]: 1991 XJS-12 for sale
CTH Automotive
10-10-2016 10:39 AM
