How to rotate camshafts?
How do I rotate the camshafts without damaging anything? I am currently doing a headgasket job. I timed everything before removing everything but had to remove the camshafts when working on the engine head. I currently have the engine head installed and the camshafts bolted onto the head but not lined up/timed. The timing chain and sprockets are currently disconnected. Thanks!
Thanks I was able to to move the camshafts by removing the timing chain retainer and a $6 harbor freight spanner wrench. Now I have another issue, I can't remember how the sprockets are arranged! .... I had everything zipped tied and ready to go but do frustration I clipped all the ties holding the sprockets and chain together and now can't remember
Do the sprockets go on the camshafts this way?
Or this way? And I'm assuming the protruding nipple goes into the camshaft. I'm losing my memory
Thank you! no wonder I was having such a difficult time trying to do it last night at 2am . After more research, the nipple part of the splined drive plate is suppose to face towards the radiator. The pictures in the Haynes manual is confusing to me!
xjrwithproblems
05-12-2011 08:37 PM
