XJ40 ( XJ81 ) 1986 - 1994
hub carrier pivot pin spacer
Old 02-23-2014, 06:51 AM
signalred's Avatar
Default hub carrier pivot pin spacer
hi guys,
does anyone know how you decide on the size of a new pivot pin spacer to replace the one taken out, as this one is damaged.. Sizes seem to go from3.905 to a range of about 8 sizes.
car is 1992 xj40 sov.
regards signalred
Old 02-23-2014, 06:55 PM
GGG is offline
Received 16,861 Likes on 12,186 Posts
signalred,
I've moved your question from XK120 XK140 XK150 (1948-1962) to XJ40 (1986-1994) forum.
Members here with the same model will be able to help.
Old 02-24-2014, 06:27 AM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
even when damaged, you should be able to use a micrometer or digital calipers in the remains to determine its thickness
Johnken
04-08-2018 10:21 AM
Dave1109971
12-15-2015 06:16 PM
ziondio
09-29-2015 01:58 PM
magmedia
09-28-2015 09:49 PM
Quick Reply: hub carrier pivot pin spacer
