HVAC blows cold air from the floor vents.
After replacing my radiator I've noticed that though I am getting hot air from the dash vents and defrost I am getting cold air from the floor vents.
I have tried cycling all the controls and everything appears to be working. Ive looked at a component diagram from Mitchell thinking there is a stuck blend door motor of some kind but I am not seeing anything as to how it could blow hot through the upper and cold through the floor.
I have searched for this issue but haven't found anything significant.
Thoughts?
Thoughts?
Jeh:
Sticky blend flaps seem to be a common fault. Same thing happened on my '94 going into the fall last year, and after some research I decided to start with basics. I undid the passenger knee bolster to gain access to the HVAC box and hit it hard a few times with the butt of a screwdriver. Blend flaps let go and now everything works perfectly! I'd try that first.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Scott
Scott
OkieTim
09-08-2015 04:48 PM
