Hydropneumatic leveling SLS :Electrical issue
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi all
Sorry for the title: this is not HYDROPNEUMATIC but hydraulic
I am taking control over a recently bought XJ40 1989 Daimler.
The first priority issue is to make the SLS system working.
The fuse located into the right side panel on place A1 (a 2 amp fuse) is fusing after some minutes of ride
When not fused, the rear suspension is working as expected
I tried to read as much as possible on this topic , here on the forum and other related ressources; but not able to understand was is the cause of such electrical problem.
I add that the cruise control unit is erratic; some times it can be engaged, but not possible to have it working again after a pression on the brake pedal.
I would greatly appreciate some directions on where to search for faults (the wiring diagrams I was able to look at did not help so far).
Thanks in advance.
Thanks in advance.
CHELMI (03-22-2016)
hawaiianjag
03-17-2016 05:58 PM
Jaguar Forums Editor
Jaguar Press release
03-17-2016 12:48 PM
