i have a few questions
the dash says i have a power fluid low and anti lock failure, the fluids are all topped off , the anti lock isnt a big deal. do these sensors go bad often?
also the car runs smooth but from a stop it doesn't seem it have a lot of get up and go, is it just these cars or do you think something is wrong? the last 3 cars ive owned were v8s, maybe im just use to them.
1988 xj6, I6, 136,000 miles.
lhm fluid? the fluid for the suspension? my car is on coil springs so i guess its been converted? , is it used for any thing else? (sorry jaguar noob )
ok so after reading up on it ive found out i still have the original suspension so ill order some fluid . this is the right stuff correct?
http://cgi.ebay.com/ebaymotors/ws/eB...ategory=111120
thanks
thanks
is there any way to turn off these sensors ? im sick of seeing the flashing lights on the dash.
also my a/c heater control panel doesn't work, the lights come on but nothing works. is there a way to test to make sure that it is the control panel?
