I love my Jag, but...
Guest
Posts: n/a
'lo, gents!
I recently acquired my first Jag, a 1990 XJ40 in remarkably good condition for a remarkably low price. Now I understand why. It does seem to have some of the electrical problems you gents have discussed at length, and I have no problem with the idea of this being a long term project car. It's a beautiful car with an awesome ride.
Today, after three weeks of driving around with the slightest bit of shudder around 1000 RPM's, it started doing something which has always scared me on previous projects. When I accelerate, it chokes, and almost dies out. I know this is typically an air / fuel mix problem, and in the past has entailed replacing an O2 sensor or a PCV valve. Can someone offer a suggestion as to where I start troubleshooting this issue?
Guest
Posts: n/a
RE: I love my Jag, but...
Sorry for my slow response. I found out that I can't access the site from the office due to a restriction on the firewall to the category 'Automotive'. Damn IT and their failure to account for my need to post about my Jag.
I've replaced the air filter and cleaned the fuel injectors. Still ahead on my short term plan are the O2 sensor and PCV valve. However, aside from that one afternoon, she hasn't repeated this behaviour. This must be one of the intermittent bugs I've seen several of you posting about.
It will probably take me 4-6 weeks to work my way through the standard list of high mileage maintenance items I like to do on any car over 100K Miles, so I'll keep you posted.
I did look at Jaguar-Lovers, by the way, and although they have quite a bit of information, the format of that site is a bit confusing. I'm much more familiar with this interface.
Add to your list of normal maintance to clean the crank position sensor. It's at the front of the timing coving at the harmonic balancer. It easily picks up road dirt and doesn't read correctly. Just wipe it down. No big deal. Probably don't even need to remove it. Just get a rag in around the head.
Mine did that in the winter a lot. I got new fuel injectors put in, and that's when it started doing that. I just stopped driving it for a while because I was scared, and than it hasn't done it to much since. I think it was mainly caused by the cold weather, cuz this was around when it was -5 degrees average in Chicago for a good month.
Do yourself a favor and save a lot of money. Go to your dealer and have the car scanned for codes. This will pinpoint any faulty sensors and you might be suprized which one is causing you grief. Mine was stalling and had an intermittentcheck engine light which when it came on had the catrunning like crap. Truns out to be a faultycoolant temp sensor causing all the rest to act oddly. If you want to keep a Jag you need deep pockets and remember for your overall investment they're terrible to resell or get any money back. Drive it, love it, then dump it. Do not put a lot of your hard earned money into it. All that said, you'll get a lot of advice when you have a Jag... some even usefull. But trust me on this before you get too far intoit. Go to the dealer and have it scanned. It will cost you an hours labor charge and is well worth it.I replaced a lot of good parts for no reason on the advice of other usually starting with "Well...90% of the time it's..." I've found 100% of the time they've been wrong.
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
innzane
09-02-2015 10:08 AM
