Identification of a wire
It's inside the front bumper (XJ40 91), goes across the middle, with large yellow connectors clipped on right and left side of the bumper. I can't figure out what the wire is for..
I'm repairing the electrical system, and apparently the wire was cut before, I believe by bumping into something. Since not every electrical system is functioning, it's hard to diagnose what it's for.
Any help would be appreciated!
Sounds like you have found the electrical feed for the fog lights that are installed on the Van Den Plas versions of these cars.
It helps to let us know what car you have,by putting the info in your signature,maybe even a pic or two...![Icon User](https://www.jaguarforums.com/forum/images/smilies/icon_user.gif)
Check out the XJ40 book in the sticky's,I think there is a little info on different ways to use those wires.
Cheers,Jim
Cheers,Jim
Received 13,025 Likes
If Jim doesn't have the turn signal lenses you need from Redd, eBay is the next best source for salvaged lenses, and if Jaguar still has any available new, look up the part numbers at jaguarclassicparts.com, then check availability and pricing at jaguarmerriamparts.com or gaudinjaguarparts.com (assuming the shoreline you live on is part of the U.S.).
Cheers,
Don
93SB (08-29-2015)
Hi danpop,
Cheers,
Don
Cheers,
Don
Shoreline is a on a west coast, it's a city north of Seattle. haha
Lawrence (09-03-2015)
