XJ40 ( XJ81 ) 1986 - 1994
idle rises and drops after cold start
Old 10-02-2013, 06:29 PM
jagnoob's Avatar
so the rpms are supposed to be high at first and then bleed off? kind of like a choke or fast idle that doesnt last very long?
Old 10-02-2013, 07:22 PM
AllanG's Avatar
Yes it's quite normal for a cold start. The tach should be at about 1000rpm for a few seconds then it will slowly reduce down to normal idle speed.
If you have disconnected then reconnected the battery, when you restart the car it will probably idle much higher (1200-1500rpm) for a few seconds and then begin to come down. This is because any stored position values will have been erased from the ECU's RAM.
Cheers,
Allan
jagnoob (10-02-2013)
Old 10-02-2013, 08:24 PM
jagnoob's Avatar
oh ok, i get it now. thank you for your help
JarodL
03-07-2024 01:39 AM
99xk8guy
06-05-2023 06:28 AM
tberg
09-07-2015 07:32 AM
Broken_Spanners
09-06-2015 11:34 AM
Bowman
09-03-2015 03:17 PM
Quick Reply: idle rises and drops after cold start
