idle rises and drops after cold start
Yes it's quite normal for a cold start. The tach should be at about 1000rpm for a few seconds then it will slowly reduce down to normal idle speed.
If you have disconnected then reconnected the battery, when you restart the car it will probably idle much higher (1200-1500rpm) for a few seconds and then begin to come down. This is because any stored position values will have been erased from the ECU's RAM.
Cheers,
Allan
Cheers,
Allan
jagnoob (10-02-2013)
99xk8guy
06-05-2023 06:28 AM
