Jaguar 93 XJ6 - burning smell.....?
my jaguar 93 xj6 wont stay on without me acceleratin it for a while.A burn smell comin from motor by the heads. i check oil and oil looks fine no water in it.Have no idea what it is.If u guys have any ideas please let me know i would really appreciated it.also has problem taking off.
jaguar 93 xj6 man (02-18-2014)
Welcome.
Sounds to me like you may have a throttle problem and perhaps an oil leak. Regarding the smell, do you see any oil seepage at the valve cover gasket that might be making it's way to burn on the manifold? Sometimes the screws come loose, but even if the valve gasket needs to be replaced, it's not a huge job.
I also wonder if you have any fault codes on the VCM - Vehicle Control Monitor. Is the check engine light one? Once you turn off the car, turn the key to position II (without cranking, and press the VCM button. Note any faults on the display because that may begin to help point you in the right direction.
Cheers!
Scott
Cheers!
Scott
BrentGardner
28
04-26-2024 04:08 AM
rusty37
06-07-2016 05:43 PM
