Jaguar electrical
Guest
Posts: n/a
Hello all,
I recently purchased 2 Jags....88 vanden plas and an 89 xj6. Both actually run great but the 89 has some gremlins. Until my alldata disc finishes D/ling I am at a standstill sort of. the 89 xj6 has no dash illumination whatsoever. While trying to fix this I noticed two odd things....welll on the way home with the 89 the fuse blew for the ac fan (right hand door panel area) while testing fuses I noticed power to both ac fan fuse ports even the one on drivers fuse panel.....but no power to other components in run state...except lighter does work but must not be fuse shown cause it did not read power when pressed it in but worked....sorry I should have mentioned I only have the 88 vanden plas fuse diagram from the panels to go off of. seems I am not getting run power to any fuses on either main block by door panels except the ac fans fuses....but the darn thing runs. Main thing is I have no idea how the fuel level or anything else is doing....just have a flashing square...speedo,tach work
Received 6,307 Likes
Jaguar Forums Editor
Jaguar Press release
08-26-2015 05:08 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
