Jaguar PDU Manuals & Software
#61
Corona time so time for a new chapter (hoping everybody is in good health).
I have bought an extra PDU but it was not complete, so I decided to try building the cables my self. I was able to source a bunch of connectors (only one PM4 connector for the 0755 cable) and have finished almost one set of home build cables. The connector that connects to the PDU are identical to the original, the 0756 car connector housing looks different but connector is the right one for our cars, for the PM4 connector I need some crimping isolation to finish it. But for now I am quit happy with the result! Although to be honest, I still have to test them.
Next step, building a base station because my new PDU doesn't have one.
Picture:
Top right, original 0756 cable
Top left, home build 0756 cable
Bottom right, has to become attached to PM4 connector
Bottom left, PM4 connector (need more of those)
If it works it is easy to convert a Ford PDU unit to a Jaguar unit and more people would be able to source a PDU for there own car if they would like.
Picture:
Funny, I really wouldn't have thought there was anyone else trying to build one of these obscure cables right now, but from what I've seen here I'm wrong! So, my 3130-0756-00 currently looks like this:
I currently have all the parts required to make it (not pictured is the rubber seal for the back of the CPC connector, which is currently on order). The main thing I am lacking is info on the wiring connections! I actually started a new thread about this subject, but it looks like this might be the "main" PDU thread.
@Gijzzy if you haven't already, would you be kind enough to share the details of the pin connections of this cable (including any pins which are shorted to each other inside the connectors, which is definitely the case in some of the other cables in my FDS system)?
If it helps anyone, here is a list of the connector parts needed to build one of these cables:
The car end is a 14 Pin Male CPC Connector
Components needed
(TE Connectivity part num / RS part num):
Size 17 Plug Housing, 14-Pin:
206044-1 / 680-6769
Size 17 Cable Clamp/Back Shell:
206070-8 / 709-9723
Type III+ Male Crimp Connectors, Size 16 (Various other types are available for different wire thickness and insulation thickness, make sure you choose the right ones for whatever wire you are using):
66103-8 / 238-094
Wire Entry Seal Kit, Size 17, 14 Pin:
213919-2 / n.a.
The PDU end is an 8 Pin Neutrik "Neutricon" Connector
Components needed
(Neutrik part num / Mouser part num / Farnell part num):
8 pin female solder connector kit:
OSC8F / 568-OSC8F / 1390188
Grey Cable Boot:
BSP-8 / 568-BSP-8 / n.a.
It turns out Neutricon and CPC connectors aren't very cheap, and the above has cost around £40, which is quite a lot for a cable - or maybe I'm just tight!
The diagnostic CPC connector in the XJ40 looks like this:
As you can see it has pins 2, 9, 10 and 13 populated. These pins are as follows:
2: Battery Voltage
9: Serial L Line
10: Serial K Line
13: Ground
Which I assume means that at most the CPC end of the 3130-0756-00 should contain these four pins. The critical info I need is where these wires lead to in the Neutricon connector, and whether there are any pins of the Neutricon connector that are bridged inside the connector. From what I've worked out so far, I think it's probably pins 9 and 10 (the data lines) of the CPC go to pins 2 and 4 of the Neutricon, but I'm not certain which way around. Another useful piece of info would be whether the original 3130-0756-00 wire uses sheilded cabling, and if so whether the shielding is connected at either end to a pin.
Hoping someone can help, thanks!
#62
Ich habe kürzlich ein fds 2000 für 50 Euro gekauft und jetzt versuche ich es als pdu zu verwenden.
Das fds2000 ist als Ford-Diagnose voll funktionsfähig, aber irgendwie bekomme ich die pdu-Software-CDs nicht zum Laden
Es scheint, als ob die CD-ROM sie nicht lesen kann.
Ich habe 4 Pdu-CDs mit
1041a
1055
jtp 626-7
jtp 627-10.
Was ist die richtige Reihenfolge, um sie zu laden ? Muss ich zuerst 1055 laden und dann 626-7 einlegen, um sie zu haben? Zugriff auf xjs-Dateien zum Beispiel?
Ich habe nicht das richtige Kabel für den PM4-Anschluss oder den spezifischen Diagnosestecker eines 93 xJs im Kofferraum. Kennt jemand eine Quelle für diese Kabel?
oder ist es möglich einen selbst zu löten?
meine fds hat eine später datierte toshiba cd rom, die bereits atapi ist, die fds ist von 1997 ... ist sie austauschbar mit einer anderen cdrom aus dieser zeit, die ebenfalls atapi ist?
jede Hilfe geschätzt ...
Grüße Thorsten
1041a
1055
jtp 626-7
jtp 627-10.
Grüße Thorsten
ich habe eine bitte kann ich bei ihnen für das Jaguar PDU die Software 1055 kaufen oder Downloaden ???
Vielen Dank,
Stefan.
Google translation: I have one please can I buy or download the software 1055 for the Jaguar PDU from you ???
Many Thanks
Last edited by Don B; 10-03-2020 at 06:28 PM. Reason: Repair quotation tags; provide google translation.
#63
Is there a reason you need specific the 1055 CD? Is the 626/7 I send you not working? I have 1055 on my laptop, so I can send it to you by e-mail and you need to burn it on a CD (it is a .iso file so you need a program like "PowerISO" or something similar to burn it).
In my opinion JTP 626/7 and JTP627/10 will do all the diagnostics 1055 can.
Don B (01-06-2021)
#64
Hallo.
Wir haben ein FDS 2000 CD-ROM-Laufwerk, das ausgefallen ist. Haben Sie die Leiterplatte zur Verfügung?
Vielen Dank,
Alfons
Per Google Translate:Hi there.
We have an FDS 2000 CD-ROM drive that has failed. Do you have the circuit board available?
Many Thanks,
Alfons
Vielen Dank,
Alfons
Many Thanks,
Alfons
#65
Received 13,424 Likes
Hello Alfons,
Welcome to the Jaguar Forums! It's great to have you with us.
Please visit the New Member Area - Intro a MUST and post an introduction to let us know a little about yourself and your Jaguar so we can give you a proper welcome.
Cheers,
Don
Cheers,
Don
#66
#67
motorcarman (01-17-2021)
#70
#71
Hi All,
I’ve just joined after researching for info on the FDS2000 system which I have purchased before Christmas. I’ve just spent all day cleaning it up and inspecting all the various leads and interfaces etc.
I read this thread with great interest and have already learnt a lot about what issues occur. The battery cover on the PDU is missing on mine, but have ordered a new battery based on the info here. I guess I’ll have to make a battery cover.
I plugged the base unit in and it powers up, but as many here have experienced the CD-ROM doesn’t seem to work and I managed to manually eject the caddy, discovering that I have 2 ver32 CD’s! I guess I’ll need to do the conversion with one of Gijzzy’s PCB’s
I’m a Ford guy with a handful of Mk1 and 2 Mondeo’s, a Mk6 Escort Cabby and a few others, but appreciate the Jaguars as a close friend has 3 modern Jags, including a rather special black Super V8
#72
#74
The original Sony cd drive needs to 'warm up' and takes around 30 minutes, you can try that first if you can get it to work.
#75
thanks for the email, I will reply via email about the circuit board.
By coincidence, I checked the CD Drive following a few hours of charging the PDU and it was on and had ejected the CD Caddy, I pushed it back in and it’s trying to read but isn’t able to load the data up to the PDU. I cleaned and tried both discs but it didn’t work, so it could be the head needs cleaning. What’s the best way to do that? I’ve never ventured that far with CD Players.
#76
Either get the conversion board and use a standard ATA drive, or open the original drive up and replace the surface mount capacitors. There are a few guides online if you’re fairly decent at soldering. I revived mine, but also have a stack of spares so I don’t quite need the conversion board yet.
#77
#78
Have dealt with enough of these Sony-bus caddy drives to know it’s not a dirty head issue. The issue stems from bad capacitors on the drive’s PCB. The classic Apple community is well aware of this issue (Apple’s external AppleCD uses a Sony drive like our PDUs). Usually with enough patience, “warming up” the drive helps immensely, sometimes power cycles will allow it to operate long enough to load data and get the PDU operational.
NTL1991 (01-04-2022)
#79
Due to high demand, I had to take the production line into action. In a few months I have send to UK, Hungary, Germany and someone local in the Netherlands
Building a new batch:
Testing the new batch:
Two ready, other two only needs a flat cable
Good work guys to keep the classics alive, and thank you for you confidence in me!
New project is finding the Aston Martin software for it, if one of you have any leads let me know!
The following 3 users liked this post by Gijzzy:
