jaguar xj6 help please - rough idle
I have 1987 jaguar xj6 that runs and idles fine when cold.but then when it warms up and I put it in reverse or drive it idles really ruff and if you press the gas it dies. But if you put back in park it runs fine. I'm stumped help please.I already put ignition coil and fuel pump and if I open the flap on the mass air flow sensor it idles fine in drive but stumble a little
Welcome to the forum alfaro2823,
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
SingBlueSilver
08-27-2015 02:20 PM
