JDU or PDU dtc scanner
Still trying to resolve the mystery code causing my 1990 xj 6 transmission to remain defaulted to limp mode. replaced tcm, decoder module , clean rotory switch & potentiometer.. back probe most of the in / out @ tcm. no trouble code on vcm. I cannot find anyone that has working jdu / pdu dtc scanner..
Is this the only way to retrieve dtc for transmission in my car ? Anyone know of working jdu / pdu dtc scanner near seattle washington ? local expert says replace tps,, but I backprobe tested it @ tcm and it is .30 - 5.00 v .. within spec or very close as far as I know. Thanks to motorcarman I have the wiring sckematic for tcm & associated controls. Really could use a scanner though!!
JDS is a REALLY old system that will probably not help and I doubt you will find a functional unit.
PDU is the only system that will work for the ECM,TCM,ABS for the XJ40. WDS was supposed to be a replacement and we got the cables to connect to the car in the WDS setup package but the software NEVER materialized.
Keep looking??
bob gauff
Keep looking??
bob gauff
shootingbrake
09-23-2015 10:54 AM
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
