XJ40 ( XJ81 ) 1986 - 1994
Light fault on the warning side
Old 05-29-2013 | 05:55 PM
Rutty's Avatar
Default Light fault on the warning side
I have a warning light on the left of my gauges that says I have a light out. Went around the car and don't see any that are out EXCEPT the fog light on the drivers side.
I thought that the monitor for light faults only was for the main lights and tail lights... could it be the fog light?
I suppose I could just change it out and see but what fun would that be.
Old 05-29-2013 | 06:03 PM
XJ40-Mark's Avatar
the bulb failure monitors ALL exterior bulbs. common failures are rear fogs, side/fender repeaters and license plate lights. 9/10 though, its the condition of the bulb holders that throw up the warnings. rear fogs rarely get used and let in water terrible!!
Old 05-29-2013 | 09:19 PM
MidwestJag's Avatar
Mark is right. And, the solder on the Bulb Failure Modules themselves corrode and crack over time, throwing that fault light. Whenever mine goes off on the '91, I know to go to the right rear of the car and tap the side running light. The light comes on and the warning light goes out!
Scott
Old 05-30-2013 | 08:54 AM
Rutty's Avatar
Thanks for the great advice. I will check around the car and see what I can find and also replace that bulb.
JarodL
03-07-2024 02:39 AM
D.K
12-10-2023 03:05 AM
99xk8guy
06-05-2023 07:28 AM
OkieTim
09-02-2015 01:48 PM
bkeats
E type ( XK-E )
09-02-2015 10:38 AM
Quick Reply: Light fault on the warning side
