Light problems
Hi, I've got a '88 Sovereign. I've been having trouble with my puddle lights not working, my front interior and map lights not working either and the back of the seat lights don't work. I've got no power to all of them regardless if the switches are on or off. I've replaced all the realays and put new bulbs all around but still not working. The rear pillar lights work.
Can someone please help me 👍
Received 13,103 Likes
Hi dom777,
Have you checked all the associated fuses? I believe all of those lights are controlled via the Central Microprocessor/CPU. Water damage to the CPU electrical connector or circuit board is a known issue, either because the duck bill drain in the windshield under-cowl (near the windshield wiper motor) has become clogged with leaves, or the A/C drains have become clogged with deteriorated foam insulation inside the Climate Control Unit (CCU).
You can download the 1988 XJ Electrical Guide at the link below, courtesy of our forum member Gus:
http://www.jagrepair.com/images/Elec...Electrical.pdf
Please keep us informed.
Cheers,
Don
Cheers,
Don
