XJ40 ( XJ81 ) 1986 - 1994
Lights Problem - FIXED
Old 12-04-2009, 07:17 AM
db in uk's Avatar
Originally Posted by cadillac
db,Thank you as you pointed out we found the module . There are two of them one (you told me ) running the exterior lights and the one next to it turns on / off the interior lights .
Thank you very much indeed , I will be ordering these two (just in case ) .I hope this problem will be gone forever thanks to your helps
Hi,
these are relay modules - more than one relay per module.
You only need to replace the one with the yellow base - DBC10009 for your outside light problem.
I can't remember off hand what the other modules do, but it is written on the top of them. As far as I know, only this yellow based module is a regular failure item.
When you take it out be careful with the little tab which secures the module - they can get a bit brittle sometimes.
David
Edit:
Just re-read your original post and you know what the other moddule does and why you're replacing it... Doh! serves me right for reading it too quickly!!
Last edited by db in uk; 12-04-2009 at 07:20 AM. Reason: Hadn't read the previous post correctly...
Old 08-30-2010, 03:56 PM
mrtalkradio's Avatar
Its always a good thing to do a search before posting a new thread. This is right on the mark. Except, its my front "parking lights," that don't work. All others do. I changed the 009 yellow relay to. I have been through the fuses, all looks good. Maybe the actual switch that turns on the head lights and parking lights? Nothing happens at all in position 1 from the switch. I have to use the "fog" switch(s) to turn on the rear parking and tail lights. Any help here? 94 xj6
Upon further investigation, it seems the master control switch in the second position (b) should turn on all front and rear parking lights, tail and number plate. It doesn't. I will assume its the switch. Because the switch I was using, that I thought was turning on the rear lights is the rear fog guard light. Which I presume are different than the rear parking lights. Is there a master relay for all the parking lights? Or do I go with my assumption and either fix or get another master light switch?
Last edited by mrtalkradio; 08-30-2010 at 04:37 PM. Reason: Added Model, updated information
JarodL
03-07-2024 01:39 AM
D.K
12-10-2023 02:05 AM
Shawn Svacha
11-04-2019 02:47 PM
jdzubas
10-04-2015 09:14 AM
laserguy
09-03-2015 02:02 PM
Quick Reply: Lights Problem - FIXED
