Location of backup battery for 93-94 security module?
I assume the system is similar to the one used on the '93 cars - you can see the schematic on pdf page 86:
Jaguar XJ40 Electrical Guide - 1993-1994
I don't recall a backup battery on the X300 security system either, but I may be wrong.
Cheers,
Don
This may be applicable. I'll have to look around under the dash to see if so:
https://forums.jag-lovers.com/t/xj40...ystem/250896/3
Yep, thats correct, is the battery 0.5 Ah ?
I could’nt source on in the UK, but you may be able to tape a 1Ah battery in
place, lasts twice as long. I bought a charger for mine, as the main battery
is out of the car over the winter, so I also remove the back up, discharge
it and recharge it, keeps it healthy
I found the alarm system back up battery today when I was fixing the
drivers side (UK) blower. It is completely dead - zero volts - and needs
replacing.
Am I right in assuming that replacing this will enable me to disconnect
the main battery without having to re-program the alarm each time?
replacing.
That's an interesting thread, Al. Have you looked up the TSBs that Bob Gauff mentioned? I wonder if they might mention this elusive battery?
I thought it was interesting that highhopes said, "As far as I know nobody has ever seen the back-up battery on a '94
XJ40." I will be very curious to hear what you eventually learn on this topic.
Cheers,
Don
Cheers,
Don
I think this is one of the antennas in the backlight/rear windshield glass, but I don't know if it is shared with either the phone or radio.
Bufcat
12-01-2011 06:21 PM
hlgeorge
05-05-2010 09:29 PM
