Looking to buy a XJ40. What should I look out for?
Hi all
My name is Michael and I am looking at buying my first Jaguar, a 1987 XJ40 with 255000km on the clock.
What are some things I should look out for when I go to look at this car. Keeping in mind I know little about these cars but am willing and very keen to learn!
Michael
Michael
When I looked at the one I bought, I was more that the electrical stuff worked, Windows, seats, locks, a/c and heat ect. When I drove it I looked for smooth power and good shifts.
IMHO if the brakes and tires are worn that's an easy fix. Even the suspension was not a deal killer. Maintenance I could fix trim and electrical they need expensive parts.
Michael:
You know, this does not seem to be a question the XJ40-ers get asked a whole lot any more, at least in my observation - so thanks for asking! The best/good examples of this car are going to have been taken care of by their owners along the way and shouldn't probably need too much. Bad examples of this car cannot be said to be much more than cheap transportation and will probably require extensive and expensive repairs to set straight!
Off hand? Lots of things could go wrong: door handles mentioned above; head gasket/valve seals; rack & pinion; wheel bearings; differential; HVAC blend flaps & controls... Then there are those little electrical niggles you are going to need to be cognizant of seeing as you are looking at such an early car.
Some of these things you can do yourself if you are industrious and like research. Otherwise, you gotta befriend a good, independent, Jaguar mechanic. My near-ish-by dealer will still look at my car if I asked them to; but I think that's only because they are being nice - and the cost is out of this world. An independent technician will cost less and may indeed appreciate the unique challenge of the car.
Search archives, here and elsewhere, to read up on well documented common faults. Happy hunting!
Scott
Scott
Michael,
Sorry one more thing... Yes, pre-1990 cars will likely have the air suspension known for failure. Most guys have converted it to a conventional set up - which I can only imaging the car you are looking at has already done. But if it hasn't, and if you are planning on keeping the car for a while, write it into your budget!
Scott
Scott
I spoke to my local Jag Dealer before buying my XJ and he said the engine and gear box are good and will last forever. (Even if not in their prime condition) but the main thing to look out for is any sort of noise from the diff.
He also mentioned to check it for cancer in the boot under the carpet.
From personal experience, if you inspect a potential purchase XJ40 and it has any electrical faults at all, walk away. They are plagued with all the usual Lucas faults. A common problem is that the battery drains to dead flat over seven or eight days. I've spent two years and around $2,000 and whilst I have resolved many electrical issues, I still have a few challenges to find and fix.
250,000 kms should not be a major problem if the car has been well maintained.
Despite the electrical issues, I personally believe the XJ40 is truely one of the best Jags ever.
![Name: DSC_0128Small.jpg
Size: 59.2 KB](https://www.jaguarforums.com/forum/attachments/xj40-xj81-25/168414d1501280221-looking-buy-xj40-what-should-i-look-out-dsc_0128small.jpg)
Bob in Oz
Bob in Oz
