looking for differential '91 Sovereign
I just got the word from my shop that the differential (rear end) of my '91 Sovereign is bad. Learned that after he had already replaced the rear wheel bearings. The car runs very well, & with the money I've put into it during the last year, I'd like to keep it going for awhile longer.
Anyone know where I might find a used differential in decent condition for a reasonable price? The shop tells me it must be from a 90 to 92 only, and not from a VDP.
sharay38 (02-03-2013)
The difference between Sovereign or base XJ6 is locking (VDP) vs. non-locking. Exactly what that entails, I'm not sure.
I think I've found one. The prices have ranged from $300 to $700 & I found one for $150. My shop tells me that the labor to rebuild would be off the charts, and swap labor is bad enough.
Thanx,
Ray
Thanx,
Ray
Well, the repairs weren't quite as expensive as I was expecting - thanks to the shop owner who gave me a break. Even the mechanic commented that it runs and rides better than most newer cars. Then the left passive restraint quit working. The cable is attached to the clip where you fasten the belt...and that is what is broken. It came off loose in my hand as I was inspecting what to do. I'm thinking the smart thing to do would be obtain a combination shoulder/lap belt and just affix that to the post and undo the passive system all together.
Received 10,862 Likes
Without delving into a long discussion on the semantics of the various types of differentials I think your mechanic meant to say "limited slip" instead of "locking".
Anyhow....
I'm not at all sure that VDPs necessarily had the limited slip differnetials but, either way, it's not a requirement. If you don't care about having limited slip your field of choices would open up quite a bit
Thanx,
Ray
Thanx,
Ray
The differentials on the Xj40s and X300s don't have the best reputation so, IMHO, a used unit is a bit risky.....especially considering the labor charges which would be doubled if you happened to get a bad unit and had to pay labor again when/if you found a good unit.
Anyhow....
Anyhow....
Your advice about used parts bears merit. For various reasons, at this time it's the way for me to go.
jimforrest (uk)
02-28-2019 06:42 PM
Woznaldo
09-26-2015 11:02 AM
