Misfire then cuts out when warm.
Is it giving any clues like smoke or sounds? Off the cuff, I think I would check fuel supply first, if the pump is heating up and cutting out consistently it may not give a clue. Also a quick and easy check might be under the distributor cap. I recently had my center button get stuck causing a no start. An aggravatingly simple fix. Good ;uck!
Don B (01-14-2018)
Received 13,425 Likes
Hi jjd,
The first thing I would suggest is that you check the Vehicle Condition Monitor for any stored Diagnostic Trouble Codes (DTCs). To do so, turn the key to position II (ON) but do not start the engine. Press and release the VCM button on the trip computer alongside the steering wheel. Now watch for a message in the small window below the speedometer where the odometer/mileage display usually appears. DTCs are displayed in the form of "FF" or "Fuel Fault" plus a two-digit number (there are some one-digit codes on the '87-'89 cars). Examples of how codes appear are FF89 or Fuel Fault 22.
Write down any DTC exactly as it appears and post it here and we'll try to help.
Problems like this are often the result of multiple contributing factors, so my first question for you is: how long has it been since the car had a good tuneup? Air filter, fuel filter, sparking plugs and leads, distributor cap and rotor, air intake plumbing and throttle body cleaned, throttle position sensor cleaned, crankshaft position sensor body and electrical connector cleaned, ignition coil and amplifier wiring inspected, fuel injector cleaner in a tank of petrol, drive belts re-tensioned or replaced, battery power and ground connections throughout the car cleaned, etc.?
Some other possible suspects would include a problem with the engine coolant temperature sensor (CTS) that if stuck on a cold setting causes the engine control module (ECM) to continue applying cold-start fuel enrichment even after the engine warms up; a problem with the oxygen sensor, which the ECM ignores for its initial warm-up period before going into closed-loop fueling. Also possible is a failed diaphragm in the fuel pressure regulator allowing unmetered fuel to be inhaled into the intake manifold, causing a rich air-fuel mixture. You can test for this by pulling the vacuum hose off of the regulator, cranking the engine, then checking for wet fuel at the vacuum hose fitting on the regulator which indicates failure of the diaphragm.
Cheers,
Don
VCM displays..pad fail. Do that is another days work plugs leads etc appear to be fine....now this car was laying up for a few years before I rescued her and was let run out of fuel on a number of occasions. I have filled with fuel and a hard driving seems to be lessening the issue. Where is the fuel filter as I feel a new filter could do wonders for her.
Good luck
Don B (01-23-2018)
. No problems at all since I replaced the sensor, engine runs smooth and has lost it's intermittent misfire. Unfortunately, as I am now retired and don't use her as much as I should plus the fact that my alternator has just seized, it is now time for her to be reborn as a fridge freezer and go to that great scrap yard in the sky. Good luck
Andreas Schmieg
11-12-2017 07:29 AM
lcyoung
09-10-2012 08:57 PM
