motor running only one side
ok so i 94 xj12 and i fix some things on it ,when it started ,it ran fine but when i give it gas it takes a second or two to get up in rpm's , so i found out only one side of the motor was firing ,exhaust was only coming out one side ,the side that did fire, i took off the exuast at the cat and it was pluged bad you could tell it had heated to a point that it wraped the metal but i un pulged it and its still wouldn't fire on that side , so did a few things with the vacum line that gos to the fuel rail and got the other side to fire but it still is lacking power and dosen't rev like it should ????? is the motor f**ked from the cat being pluged that bad
,it runs fine on the one and when i get the other side to fire but acceleration not there
I would remove the cat from the exhaust manifold on the plugged side. The cat is probbably garbage if it was built up that bad. Or at least unscrew it from the manifold so you have a large leak. Take the car for a spin and see if you have returning power and firing.
If you are still having power loss I am guessing the heat build up probably burned valve(s). I would remove the cat and drive the car and see if it improves. Otherwise a compression test will tell you if you are having mechanical problems.
I am not sure if I understand that you were sure none of the cyls on that side were firing. Sounds like the clogged cat was your problem.
yeah there is some wrong on that side of the motor ,i can get it to fire only by holding the throttle above idle, then it cuts out when i rev it, but will at time fire agian when holding it at higher rpms , and after i get it to fire and put it back at idle it misses or only some cylinders fire at times ,
then last it had back fired once after revving it ,but i think thats from the gas not burning in the cylinders then one fires and burns all the gas in the exhaust
so you think this sounds like burned valves ????and can i dive it tell the motor gives out then repair it ???
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
Well I am sure there is someone else here that can chime in with better advice but I think it is probably a valve issue.
I think this because you get intermittent firing that you describe as erratic and acts better at higher rpms. I would guess burned valves/valve seats because of the obvious extreme heat that was in the area. Have you taken the plugs out and looked at them? Do they look oily or very white?
You can still drive the car but I have read that for long periods it can lead to a 'glossing of the piston walls' which will cause poor compression and require a whole lot more work. If you drive it untill the engine dies then you may risk needing to at least have your block remachined and have new piston rings installed.
If I where you I would check e-bay, there are often refurbished complete heads for sale. Even a complete used one from e-bay or craigs would work.
But first I would spend a few hours and do a compression test, check lifter clearances, make sure you are getting good clean spark, all injectors are working, then go from there.
I am unfamiliar with the v12 engine but I do not think the engine needs to be removed to remove the head(s).
You might not need to replace either of the heads, I am sorry if I sounded like you had to. If the head did infact warp then a machine shop can usually machine it out if it is not an extreme case. If the head cracked then you would probably want to find a replacement. You should not need to replace both heads if only one were to be bad.
However I would not assume I had a warped head, it is just something that can happen due to high heat. I would guess it is not your problem. My guess is you have one or more burned valves or valve seats.
However it could just be that some of the valves are out of adjustment.
To check clearances you need to first find the firing order of your engine. (jag-lovers probably has a guide for this as well.) Then you will set the number one cylinder to TDC.
After that you can take the valve covers off to expose the cam shafts. [You should replace the gaskets for the valve cover upon reinstallation or you may leak oil]. There is one camshaft per side. You will notice the camshaft lobes. There will be 2 lobes for each cylinder.
One of the lobes opens the intake valve and one of them the exhaust. You will notice that the lobes on the number 1 cylinder at TDC will both have their elongated parts sticking outward opposite of eachother. In other words neither lobe is pressing on the valve tappet so both valves are closed. You will use a feeler guage to measure the distance between the camshaft lobe and the tappet while that cylinder is at TDC. Then you will rotate the engine(by hand) to bring cylinder number 2 to TDC and you will then measure its lobes with the feeler guage. Continue for all 12...
If anything looked scored or otherwise deformed that is a sign of a problem.
Although I do not think there is a Haynes manual for the v12 model I recomend you pick up the Haynes for the xj40 anyways before you do any real work. You can gain a lot of the technical ideas from the book and then apply them to your car.
Injectors can be listened to with a mechanics stethoscope or by putting a bar up against the injector and listening to the bar. The idea is to hear the injector clicking as it opens and closes to inject fuel. The bar will help amplify the sound comming from each injector. You should hear a fairly fast paced ticking if the injector is operating.
If the plugs were black and gummed up then there may be oil entering the cylinder. Is there any noted oil loss? What do the new plugs look like?
Did you do a compression test? This is an easy test. If you have good compression then your problem may not be in the valvetrain or head at all.
It might be worth your wile and time to take it to a shop and have them look at it. They will be able to perform a leak down test quite quickly and note other signs that will point to the probable cause as well.
Again I don't know what the specific numbers are for valve clearance, compression pressures, etc. However they can probably be found here without much difficulty. ImageShack® - Online Photo and Video Hosting is a photo of the camshaft assembly for the xj40 v12 to help you get an idea.
the side of the motor that was giving me all the problems has no spark or very little at times and when i switch one of the wires from the side of the motor that runs good it gets better but its dosen't spark like it should looks really weak compared to the other side
The rotor arm has two sides on the V12; one fires bank 1, the other fires bank 2.
If one side of the rotor arm becomes worn out and stops producing a spark at the plugs on that bank of cylinders, the other can still continue to fire the cylinders on the other bank as normal, thus one half of the engine continues to run. As the engine runs, the other non-running bank dumps the fuel down into the exhaust causing a fire. It goes without saying, but don't run the engine like this!!
The rotor can fail and cause this problem in the absence of any other issues, so it could be that there are no other engine problems in your car. If the fire has not damaged anything important under the bonnet (hood) a new distributor cap and rotor arm could solve the problem, along with a new catalyst, at least on that side.
David
db in uk is correct that the rotors can fail.
Replace the rotor arm and see if it runs normally.
If it still runs only on one bank, swap the ignition coils and see if it runs on the other now.
I have a box full of burnt out coils and rotor arms for the V12 engines. It is a common problem.
good luck
bob gauff
good luck
bob gauff
today i got my cap rotor and wires i installed them and when i went to start the car same thing only half the motor was running so i thought i should try and switch the coils sense it the last thing i can try before i give up now all switched i start the car and the side that didnt run was running and the side that was now it wasnt so the A coil was bad now im off to get a new one
what a good day thanks every one for your help couldn't have done it with out you![Icon Chickendance](https://www.jaguarforums.com/forum/images/smilies/icon_chickendance.gif)
:icon_chickendance :![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
:ico n_chickendance:![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
:ic on_banana:![Icon Chickendance](https://www.jaguarforums.com/forum/images/smilies/icon_chickendance.gif)
